DEMANDLOAD system variable
Demand load
Specifies how BricsCAD interacts with custom entities created by a third-party application. If you set this system variable to 0, third-party applications and some BricsCAD commands cannot function.
Type: | Short |
Saved in: | Registry |
Range: | 0 to 3 |
Default value: | 3 |
Possible values: |
1: Demand-load source application when opening a drawing that contains custom entities 2: Demand-load source application when invoking one of the application's commands |
