DGNEXPXREFMODE system variable
Export Conversion of Xrefs
Specifies conversion of references to xrefs. The dependent files themselves are not converted when exporting the parent. They must be converted separately.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Preferenza |
Valore predefinito: |
0 |
Valori possibili: |
0: Convert reference to DGN 1: Keep reference to DWG 2: Bind reference file to the parent DGN 3: Detach xref |
