DGNEXPXREFMODE system variable
外部参照的导出转换
Specifies conversion of references to xrefs. The dependent files themselves are not converted when exporting the parent. They must be converted separately.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Default value: |
0 |
Possible values: |
0: Convert reference to DGN 1: Keep reference to DWG 2: 将参考文件绑定到父DGN 3: Detach xref |
