DGNIMP2DSHAPEIMPORTMODE system variable
2D shape import mode
Specifies how to convert 2D Shape and 2D Complex Shape elements. If an element is filled, then a hatch is created as well as the result of importing.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: | 0 to 2 |
Default value: | 0 |
Possible values: |
0: Convert to polyline 1: Convert to region 2: Convert to polyface mesh |
