DGNIMPBREAKDIMENSIONASSOCIATION system variable
Break dimension association
Specifies if dimensions lose their associativity upon import. If on, then dgn dimension associations are broken in the dwg.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t break dimension associations On (1): Break dimension associations |
