DGNIMPBREAKDIMENSIONASSOCIATION system variable
Break dimension association
Specifies if dimensions lose their associativity upon import. If on, then dgn dimension associations are broken in the dwg.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | Off |
Possible values: |
Off (0): Don’t break dimension associations On (1): Break dimension associations |
