DGNIMPCONVERTEMPTYDATAFIELDSTOSPACES system variable
Convert empty data fields to spaces
Specifies how empty field values are handled. If on, then empty field values from a dgn file are replaced by space symbols in the dwg file. Otherwise empty field values from a dgn file are replaced by underscore symbols ("_") in the dwg file.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Replace by underscore symbols ("_")
On (1): Replace by space symbols
