DGNIMPEXPLODETEXTNODES system variable
Explode text nodes
Specifies how to handle text nodes (empty text fields). If on, imported dgn text nodes are converted to simple entities (text, line, etc.). Otherwise they are converted to multiline text. Microstation uses text nodes as empty fields that are used to reserve space for text that will be added later so the length of the text is not yet known.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
Off
Possible values:
Off (0): Convert text nodes to multiline text
On (1): Convert text nodes to simple entities, such as text and lines
