DGNIMPIMPORTINVISIBLEELEMENTS system variable
Import invisible elements
Specifies how invisible elements (entities) are handled. If on, BricsCAD imports invisible dgn elements as invisible entities. Otherwise they are skipped.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | On |
Valori possibili: |
Off (0): Skip invisible elements On (1): Import invisible elements |
