DGNIMPIMPORTINVISIBLEELEMENTS system variable
Import invisible elements
Specifies how invisible elements (entities) are handled. If on, BricsCAD imports invisible dgn elements as invisible entities. Otherwise they are skipped.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Skip invisible elements On (1): Import invisible elements |
