DGNIMPIMPORTINVISIBLEELEMENTS system variable
Import invisible elements
Specifies how invisible elements (entities) are handled. If on, BricsCAD imports invisible dgn elements as invisible entities. Otherwise they are skipped.
BricsCAD only
Type:
Boolean
Saved in:
Preference
Default value:
On
Possible values:
Off (0): Skip invisible elements
On (1): Import invisible elements
