DGNIMPIMPORTPAPERSPACEMODELS system variable
Import Paper Space models
Specifies whether to import sheet models (paper space). If on, all dgn sheet models are imported to the Paper Space layouts. Otherwise sheet models are not imported. Microstation uses the phrase “sheet model” for paper space.
BricsCAD only
Type: | Boolean |
Saved in: | Preference |
Default value: | On |
Possible values: |
Off (0): Don’t import sheet models On (1): Import sheet models to paper space layouts |
