DGNIMPIMPORTVIEWINDEX system variable
Import view index
Specifies the number of dgn views to use level masks and dgn view settings. If the view number is "-1", then the view is not defined, and view settings and level masks are not used. Microstation uses the word "level" for layers; a "mask" hides content in areas or levels/layers.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Preferenza |
Gamma: |
-1 to 7 |
Valore predefinito: |
-1 |
Valori possibili: |
-1: View is not defined 1 to 7: Specifies level mask |
