DGNIMPIMPORTVIEWINDEX system variable
Import view index
Specifies the number of dgn views to use level masks and dgn view settings. If the view number is "-1", then the view is not defined, and view settings and level masks are not used. Microstation uses the word "level" for layers; a "mask" hides content in areas or levels/layers.
BricsCAD only
Type:
Short
Saved in:
Preference
Range:
-1 to 7
Default value:
-1
Possible values:
-1: View is not defined
1 to 7: Specifies level mask
