DGNIMPRECOMPUTEDIMENSIONSAFTERIMPORT system variable
Recompute dimensions after import
Specifies how to handle imported dimensions. If on, BricsCAD will re-compute all dimensions to create dwg-based dimension geometry blocks; otherwise it will create dgn-based dimension geometry blocks.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Preferenza |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): create DGN-style dimension geometry blocks On (1): re-compute all dimensions to create DWG dimension geometry blocks |
