DGNIMPXREFIMPORTMODE system variable
External references import mode
Specifies how to import dgn reference attachments. The options are "Omit" - don't import dgn reference attachments; "Retain" - convert attached dgn files to dwg and create dwg Xref; "Merge to cell" - create block definition and import attached dgn file to it, then create block reference to dgn attachment block; "Create DGN Underlay" - create DGN Underlay object.
BricsCAD only
Type: | Short |
Saved in: | Preference |
Range: | 0 to 3 |
Default value: | 2 |
Possible values: |
0: Omit 1: Retain 2: Merge to cell 3: Create DGN Underlay |
