DIMADEC system variable
标注角度精确度
Specifies the display precision for angular dimensions. Values between -1 and 8 are accepted. If -1 is entered, DIMADEC is initialized with the value of the DIMDEC setting. Values 0 to 8 specify the number of decimal places for angular dimensions, independent of DIMDEC.
Type: | Short |
Saved in: | Drawing |
Range: |
-1 to 8 |
Default value: | 0 |
Possible values: |
-1: Use DIMDEC setting 0 - 8: Decimal places |
