DIMADEC system variable
Dim angle precision
Specifies the display precision for angular dimensions. Values between -1 and 8 are accepted. If -1 is entered, DIMADEC is initialized with the value of the DIMDEC setting. Values 0 to 8 specify the number of decimal places for angular dimensions, independent of DIMDEC.
| Type: | Short |
| Saved in: | Drawing |
| Range: |
-1 to 8 |
| Default value: | 0 |
| Possible values: |
-1: Use DIMDEC setting 0 - 8: Decimal places |
