DIMALTF system variable
替用单位倍数
Specifies the multiplier for alternate units. If DIMALT is on, linear dimensions are multiplied by DIMALTF to provide an alternate linear dimension. E.g. if one drawing unit equals 1 inch, and DIMALTF=25.4, alternate linear dimensions are expressed in mm.
Type: | Real |
Saved in: | Drawing |
Default value: | 0.0394 |
