DIMALTTZ system variable
Alt tolerance suppress zeros
Specifies the suppression of zeros in tolerance values.
Type: | Boolean |
Saved in: | Drawing |
Default value: | 0 |
Possible values: |
0: Suppress zero feet and precisely zero inches 1: Include zero feet and precisely zero inches 2: Include zero feet and suppress zero inches 3: Suppress zero feet and include zero inches 4: Suppress leading zeros in decimal dimensions 8: Suppress trailing zeros in decimal dimensions |
