DIMAPOST system variable
Alt units prefix/suffix
Specifies a prefix and/or suffix that to appear in the alternate dimension text. The general format is just the suffix string or 'prefix[]suffix'. DIMAPOST does not apply to angular dimensions. In the DimStyle explorer the variable is split up into Alt Prefix and Alt Suffix for editing.
Tipo: | Stringa |
Salvato in: | Disegno |
