DIMATFIT system variable
箭头及文字填入
Specifies how dimension text and arrows are arranged when there is insufficient place within the extension lines. When DIMTMOVE=1, a leader is added if the dimension text is placed outside.
Type:
Short
Saved in:
Drawing
Range:
0 to 3
Default value:
3
Possible values:
0: 文字和箭头都放到扩展线外侧
1: 先移动箭头,再移动文字
2: 先移动文字,再移动箭头
3: 视情况移动文字或箭头
