DIMATFIT system variable
Arrow and text fit
Specifies how dimension text and arrows are arranged when there is insufficient place within the extension lines. When DIMTMOVE=1, a leader is added if the dimension text is placed outside.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 3 |
Default value: | 3 |
Possible values: |
0: Place both text and arrows outside extension lines 1: Move arrows first, then text 2: Move text first, then arrows 3: Move either text or arrows, whichever fits best |
