DIMAZIN system variable
Suppress angle zeros
Suppresses leading and/or trailing zeros for angular dimensions. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 3 |
Default value: | 0 |
Possible options: |
1: Suppress leading zeros 2: Suppress trailing zeros |
