DIMCEN system variable
Center mark
Specifies if and how center marks and centerlines of circles and arcs are drawn by DIMCENTER, DIMDIAMETER and DIMRADIUS commands. Set to zero for no center mark, negative for Line or positive for Mark. The DIMCEN system variable also controls the length of center mark lines and size of the center marks.
| Type: | Real |
| Saved in: | Drawing |
| Default value: | 0.09 |
| Possible values: |
0: None <0: Line >0: Mark |
