DIMFXLON system variable
Ext line fixed
Specifies whether extension lines are set to a fixed length.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t use fixed length extension lines On (1): Use fixed length extension lines |
