DIMGAP system variable
Text offset
Specifies the offset distance around the dimension text and the distance between annotation and hook line created using the LEADER command. A negative value for DIMGAP draws a box around the dimension or annotation text.
Tipo: | Reale |
Salvato in: | Disegno |
Valore predefinito: | 0.09 |
