DIMGAP system variable
Text offset
Specifies the offset distance around the dimension text and the distance between annotation and hook line created using the LEADER command. A negative value for DIMGAP draws a box around the dimension or annotation text.
Type:
Real
Saved in:
Drawing
Default value:
0.09
