DIMJOGANG system variable
Jogged angle
Specifies the angle of the oblique dimension line segment in jogged radius dimensions. Jogged radius dimensions are often created when the center point is located off the page.
Tipo: | Reale |
Salvato in: | Disegno |
Valore predefinito: | 45.0 |
