DIMJOGANG system variable
横线段角度
Specifies the angle of the oblique dimension line segment in jogged radius dimensions. Jogged radius dimensions are often created when the center point is located off the page.
Type: | Real |
Saved in: | Drawing |
Default value: | 45.0 |
