DIMJUST system variable
Horizontal text position
Specifies the horizontal position of dimension text, with respect to the extension lines.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: | 0 to 4 |
Valore predefinito: | 0 |
Valori possibili: |
0: Text above the dimension line and center-justified between extension lines 1: Text next to the first extension line 2: Text next to the second extension line 3: Text above and aligned with the first extension line 4: Text above and aligned with the second extension line |
