DIMLFAC system variable
Dim scale linear
Specifies the scale factor for linear dimensions. Linear dimensions (incl. radius, diameter and ordinate dimensions), are multiplied by DIMLFAC. Positive values apply to dimensions in both model space and paper space; negative values apply to paper space dimensions only.
| Type: | Real |
| Saved in: | Drawing |
| Default value: | 1.0 |
