DIMLIM system variable
Tolerance method
Specifies the default text to dimension limits. If DIMLIM is On, DIMTOL is switched Off.
Tipo: | Booleana |
Salvato in: | Disegno |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t generate dimension limits as default text On (1): Generate dimension limits as default text |
