DIMLWD system variable
Dim line lineweight
Specifies the lineweight of dimension lines.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: |
-3 to 211 |
Valore predefinito: | Bylayer |
Valori possibili: |
-3: Default (defined by LWDEFAULT) -2: ByBlock -1: ByLayer 0 - 211: Lineweight value in hundredths of millimeters |
