DIMLWD system variable
Dim line lineweight
Specifies the lineweight of dimension lines.
Type:
Short
Saved in:
Drawing
Range:
-3 to 211
Default value:
Bylayer
Possible values:
-3: Default (defined by LWDEFAULT)
-2: ByBlock
-1: ByLayer
0 - 211: Lineweight value in hundredths of millimeters
