DIMPOST system variable
Dim prefix/suffix
Specifies a prefix and/or suffix to be added to the dimension text. The general format is just the suffix string or 'prefix <> suffix'. A single linefeed can be inserted with '\\X' (often when alternate units are active). In the DimStyle explorer the variable is split into Dim Prefix and Dim Suffix for editing.
Tipo: | Stringa |
Salvato in: | Disegno |
