DIMRND system variable
Dim round
Specifies the roundoff rules for linear dimensions. E.g. set DIMRND to 0.1 if you want to round all distances to the nearest 0.1 unit. Set DIMRND to 1 if you want to round distances to the nearest integer. Remember the number of decimal places is limited by DIMDEC. Angular dimensions or not affected by DIMRND.
Tipo: | Reale |
Salvato in: | Disegno |
Valore predefinito: | 0.0 |
