DIMSCALE system variable
Dim scale overall
Specifies the scale factor applied to all dimensioning variables that specify the size of the components of dimension entities, such as text height, distances or offsets. DIMSCALE does not affect measured lengths, coordinates, or angles.
Tipo: | Reale |
Salvato in: | Disegno |
Gamma: | 0 or greater |
Valore predefinito: | 1.0 |
