DIMSD1 system variable
Dim line 1
Suppresses the display of the first part of the dimension line: from the first extension line to the text origin.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Don’t suppress first dimension line On (1): Suppress first dimension line |
