DIMSD2 system variable
Dim line 2
Suppresses the display of second part of the dimension line: from the text origin to the second extension line.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t suppress second dimension line On (1): Suppress second dimension line |
