DIMSOXD system variable
Dim line inside
Suppresses arrowheads outside the extension lines if there is insufficient room inside the extension lines and if DIMTIX is on. If DINTIX is off, DIMSOXD had no effect.
Tipo: | Booleana |
Salvato in: | Disegno |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t suppress outside arrowheads On (1): Suppress outside arrowheads |
