DIMSOXD system variable
Dim line inside
Suppresses arrowheads outside the extension lines if there is insufficient room inside the extension lines and if DIMTIX is on. If DINTIX is off, DIMSOXD had no effect.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | Off |
| Possible values: |
Off (0): Don’t suppress outside arrowheads On (1): Suppress outside arrowheads |
