DIMTAD system variable
Vertical text position
Specifies the vertical position of text with respect to the dimension line. If DIMTAD=1 (Above dimension line), the distance from the dimension line is set by DIMGAP.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: | 0 to 4 |
Valore predefinito: | 0 |
Valori possibili: |
0: Centered between extension lines 1: Above dimension line, unless DIMTIH is 1 and the dimension line is not horizontal 2: Farthest from defining points 3: Japanese Industrial Standards 4: Below dimension line |
