DIMTAD system variable
Vertical text position
Specifies the vertical position of text with respect to the dimension line. If DIMTAD=1 (Above dimension line), the distance from the dimension line is set by DIMGAP.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 4 |
| Default value: | 0 |
| Possible values: |
0: Centered between extension lines 1: Above dimension line, unless DIMTIH is 1 and the dimension line is not horizontal 2: Farthest from defining points 3: Japanese Industrial Standards 4: Below dimension line |
