DIMTFAC system variable
Tolerance text height
Specifies the scale factor to calculate the text height for dimension fractions and tolerances, relative to the dimension text height, as set by DIMTXT. Only applies if DIMLUNIT=Fractional.
Tipo: | Reale |
Salvato in: | Disegno |
Valore predefinito: | 1.0 |
