DIMTFAC system variable
公差词高
Specifies the scale factor to calculate the text height for dimension fractions and tolerances, relative to the dimension text height, as set by DIMTXT. Only applies if DIMLUNIT=Fractional.
Type: | Real |
Saved in: | Drawing |
Default value: | 1.0 |
