DIMTIH system variable
文字内部对齐
Specifies the position of dimension text inside the extension lines. DIMTIH does not apply to ordinate dimensions.
Type: | Boolean |
Saved in: | Drawing |
Default value: | 1 |
Possible values: |
Off (0): Aligned with dimension line On (1): Horizontal |
