DIMTIH system variable
Text inside align
Specifies the position of dimension text inside the extension lines. DIMTIH does not apply to ordinate dimensions.
| Type: | Boolean |
| Saved in: | Drawing |
| Default value: | 1 |
| Possible values: |
Off (0): Aligned with dimension line On (1): Horizontal |
