DIMTIX system variable
Text inside
Draws text between extension lines, even if there is insufficient room. DIMTIX does not apply to radius and diameter dimensions.
Type:
Boolean
Saved in:
Drawing
Default value:
Off
Possible values:
Off (0): Don’t force text between extension lines
On (1): Force text between extension lines
