DIMTIX system variable
Text inside
Draws text between extension lines, even if there is insufficient room. DIMTIX does not apply to radius and diameter dimensions.
Tipo: | Booleana |
Salvato in: | Disegno |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t force text between extension lines On (1): Force text between extension lines |
